Battery Drain
(Topic created on: 07-03-2020 01:16 PM)
arjunufc
Galaxy Note
Updated Recently in June Month, Noticed Battery Drains very quickly
3 Comments
Not applicable
Galaxy Note
use smart switch or odin ...if you simply update it then problem may arrised
vicke
Galaxy Note
bro if I use Odin or smart switch u need internet . so was de dffrnce if u download directly through phone o smarth switch I suggest .... flash it service centre
Not applicable
Galaxy Note
yes definitely...flash it from service center...best process
