Battery Drain In Samsung Note 20Ultra
(Topic created on: 09-05-2020 05:23 PM)
KuSh21st
Galaxy Note
Dear Team
I've Been Getting Trouble with Battey Life In My Samsung galaxy note 20Ultra
It's Not That Sufficient As Samsung Note 10 Plus..
It's not give me atlases 12 Hrs Backup..
Please Explain...
8 Comments
Not applicable
Galaxy Note
Yes bro now all mobile faced battry drain issue you may wait for update and also follow below step to consume battery
Optimise the device using the device care feature.
• When you are not using the device, turn off the screen by pressing the Side key.
• Activate power saving mode.
• Close unnecessary apps.
• Deactivate the Bluetooth feature when not in use.
• Deactivate auto-syncing of apps that need to be synced.
• Decrease the backlight time.
• Decrease the screen brightness
NoteFun
Galaxy Note
Do not reset any of the settings as we have bought the flagship to use at its best...Instead charge twice a day and enjoy its full capacity of multitasking & wait for future updates to get this battery drain fix...
KuSh21st
Galaxy Note
but I talk to the samsung care, they told me do not charge phone multiple times in a day.. its make your battery Weak...
NoteFun
Galaxy Note
Sir, but when battery is below 15% then you have to charge to avoid switching off the phone...So whatever they said, fact is either we have to charge twice a day or limit our usage...I think everyone should opt for first option after buying this device...
sarfarazahmed
Galaxy Note
i will be in 2 minutes of silence for u bro
Dilli
Galaxy Note
Whatever device is coming out from Noida factory 🏭 is lacking quality check SAD!🤫
KuSh21st
Galaxy Note
let's see
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
To resolve battery issue kindly follow the below step given below:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
