Battery Consumption on Android 11 Note 10 +
(Topic created on: 01-08-2021 11:36 PM)
Not applicable
Galaxy Note
Hi all,
I am noticing a higher idle battery consumption on my Note 10+ on Android 11 official os. Is anyone else also seeing this ? Call logs are taking 22 percent battery? What is this.
5 Comments
Galaxy Note
Same here, even reported to samsung as error reports but they think I am a 12yo kid who doesn't know how to use my phone.
Not applicable
Galaxy Note
dude thats hilarious. well if quite a few of us report it then maybe samsung takes notice of this. or this maybe one of those tricks called planned obsolescence at work here.
Galaxy Note
chk lol.
panglossian
Galaxy Note
🤣🤣 had similar experience when I approached them for replacement nibs for s pen
Ehsank
Galaxy Note
If after update then wait for few days, and as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable/type C earphone only for Android 11)
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
You can also send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
