Battery Charging Time - Note 10+
(Topic created on: 03-28-2020 07:53 PM)
SD716
Galaxy Note
Suddenly since last 2 days the charging time has exactly doubled!
Earlier it used to get charged in 45 to 60 mins.
But now, 2 hours!
Any solutions folks?
#battery #note10plus
11 Comments
Samsung_Support4
Galaxy Note
Dear Samsung Member,
Apologies for the delay in response. However, understanding the criticality of the situation; we had to ensure the wellbeing and safety of our employees which led to the delay in response.
Hope your issue is resolved. In case the issue still persists please follow the below mentioned steps.
1. We always recommend to use genuine Samsung charger for charging your device.
2. Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged then kindly visit your nearest service center to get it replaced.
3. Check charger functionality, try to charge your device with some other charger or use your charger to charge some other device.
4. Check charging, if rating is 15W or above. Kindly try to charge the device in a non-inverter socket.
Note: Kindly open Device care from Settings > Battery > Please tap on 3 dots(more option) at the top right hand side > please select settings > enable fast cable charging.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
SD716
Galaxy Note
there's no damage on the charger, my galaxy buds gets charged normally with the same charger, I have already reported 'error report' . So essentially there's some problem with the battery / phone itself. As charging time has doubled coupled with the heating of the phone! I shall initiate a legal suit for the same !!!
