07-05-2022 10:44 PM in
Galaxy M- Mark as New
07-05-2022 10:50 PM in
07-05-2022 10:53 PM in
07-14-2022 10:21 AM in
Galaxy MDear Samsung member,
1. Disconnect anything plugged into the headphone jack like a selfie stick, headphones, Bluetooth, etc.
2. Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
3. Check device volume settings:
Apps> settings> sound & vibration> volume> Drag the volume adjustment bar left or right to increase or decrease the device volume.
4. Check mute all sound options:
Apps> settings> accessibility> hearing enhancements> Disable mute all sounds (if enabled).
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
