Screen flickering issue and battery drain in m52
(Topic created on: 10-01-2022 09:28 PM)
pranjalrana
Galaxy M
Is after 1 August security patch update the screen flickering and battery drain issue are fixed because I have not updated because I am thinking what if it get Worse so if anyone have updated please let me know
14 Comments
pranjalrana
Galaxy M
No i play in 60hz
Galaxy M
Then there is problem
Galaxy M
In my m51 I'm also facing the same problem after the update
viveksaini90
Galaxy M
after august update not fixed screen flickering issue
cs_member8
Galaxy M
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. Please follow the easy troubleshooting steps which might help to solve the issue.
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Display.
Step3: Adjust the brightness.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
