Samsung Phone Heating/Battery Drain Issue
(Topic created on: 02-05-2025 02:11 AM)
Not applicable
Galaxy M
I bought the Galaxy M14 5G, even though it didn’t come with a Punch Hole and charger in the box, because I trusted the brand. However, after just one year, the motherboard died. Thankfully, Samsung replaced the part, but the biggest issue with this phone is the heating problem. Even when using basic apps, it gets hot quickly, and the battery drains way too fast. I have two phones: the Poco X5, which has a constant signal, while the M14 struggles to maintain one.
3 Comments
goodthings
Galaxy M
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
Your's most welcome to here.
cs_member8
Galaxy M
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
4. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
5. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
