Samsung M51 smartphone heating issue and battery draining
(Topic created on: 10-26-2020 08:41 AM)
Meetsamrat2020
Galaxy M
While charging the phone phone heats up and also after using camera app. Need software update. And also battery draining faster than usual considering 7k battery (6800 mah to be exact)
15 Comments
Galaxy M
Maybe a software problem but such issues also depend on other things like phone's case thickness, tempered glass (this won't allow the heat to dissipate from the display efficiently), brightness, ambient temperature etc.
Ehsank
Galaxy M
for battery if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
Wåne
Galaxy M
great Info 👍 thanks 😊
Ehsank
Galaxy M
Its an old i have morw info here now its up to 10😁😁
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
A. Adaptive battery
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Wåne
Galaxy M
Woah😊 Thank You
Ehsank
Galaxy M
Wåne
Galaxy M
shukran jazakallah seriously I didn't face any issues but still I took precautions as I have Rugged thick Protective Cover
Ehsank
Galaxy M
Afwan, wa ʾantum fa-jazākumu-llāhu khayran👍😊
SG17
Beginner Level 4
Galaxy M
have same heating issue while using camera ..raised to support team but no help
