10-22-2020 11:54 PM in
Galaxy MAlthough it has a Monster 7000mAh battery, it still performs just like my old Samsung Galaxy J7 (2016) with a 3100mAh battery.
Despite mild use, its battery only lasts 24 hours and I am deeply disappointed with its battery performance. ☹
10-23-2020 12:01 AM in
Galaxy Mgo to device care >battery>battery uses and check screen on time or go to settings digital wellbeing and check
10-23-2020 12:02 AM in
Galaxy M- Mark as New
12-09-2020 08:02 AM in
Galaxy MI'm getting only 13 hour SOT
12-09-2020 12:05 PM in
10-23-2020 12:41 AM in
10-23-2020 01:09 AM in
Galaxy Mplease share screen shot of screen on time page
10-23-2020 02:19 AM in
Galaxy Mas you can see in my screenshot, which I took of last date. it is showing screen on time 8 hour. I track for last few days, it is showing 8 to 9 hours screen on time.
10-23-2020 10:50 AM in
Galaxy M1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
