Samsung Galaxy M40 PUBG and battery issue.
(Topic created on: 07-19-2020 07:20 PM)
KhalidMir
Galaxy M
When i first purchased my samsung m40 a year ago i was able to run pubg on smooth + extreme graphics settings but now it has been reduced to smooth + ultra, which is disappointing. Whenever i play pubg, battery reduces drastically and allows me to play only 5 classic matches from 100% to 5%. Battery performance as well as the gaming performance is bad. After 5 - 6 minutes on gaming frame rate starts to drop and game starts to lag. And no doubt battery performance is a big disappointment. I think i should gift this phone to my grandmother and buy a better one because if i continue to play pubg on this device i might end up destroying it, it's really frustrating. And i believe Samsung phones are not meant for gaming, be it M series, S series or whatever.
6 Comments
Ganesh6401
Galaxy M
I Thought M40 Will Perform Better As It Has Snapdragon 675 Processor Rather Than Exynos 9611
KhalidMir
Galaxy M
Exactly, that's why i bought this one. But i guess it was a mistake. I should have had gone with honor play.
RohanKhera01
Galaxy M
I think m series is not properly optimised for pubg. I have m30s and battery drains fast in pubg as compared to cod or other heavy games
NikRK
Galaxy M
yes, im facing the same issues, after every update the performance of m40 is getting worse...
cs-member13
Expert Level 4
Galaxy M
Dear Samsung Member,
Please be assured and to resolve the issue kindly follow the given below steps:-
1. Check device in safe mode:- Press and hold the Power key, when Power off icon appears >Press and hold the power off icon.
Exit safe mode: Hold the power button and select restart on the device.
2. Reset the device:- Settings >General Management > Tap on Reset.
Note: Before reset make sure to have back up of the data via Smart Switch Mobile App
(Install Smart Switch App > Open > Click on Memory Card Icon >Back Up option > Choose the data for Back up > Back Up).
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
Galaxy M
I have already made an community post for all samsung devices game lag fixes please check
