Problem while using
(Topic created on: 05-25-2022 09:59 AM)
saiemk007
Galaxy M
Hello Samsung my phone has problem while using. It get restart while using. This phone is 20 month old. Please solve my problem
8 Comments
Galaxy M
Clear unnecessary memory or documents from ur phone... and force reboot it.
saiemk007
Galaxy M
Yes I have done it but no solution
anil7d
Galaxy M
Did you updated your phone recently?
saiemk007
Galaxy M
Yew ihave updated my phone but same issue
anil7d
Galaxy M
@saiemk007 You got that issue because of update.
saiemk007
Galaxy M
Yes sir
cs_member10
Galaxy M
Dear Samsung member,
There are two methods to disable the auto-restart function
Method 1: From the home screen swipe up or down to access the App Screen > Setting > General Management > Reset > Auto Restart > To Turn OFF auto-restart slide the slider toward the left.
Method 2: Go to 'Settings'>>Tap on 'Battery and device care'>> Tap on Three dots>>Tap on 'Automation'>>Disable 'Auto-restart at set times' if enabled
If you are facing this issue after installing any new application then uninstall that application.
Navigate to the Apps screen and tap on Settings>>Tap on Apps>>Tap on the desired app>>Tap on Uninstall>>Tap on OK
Reset settings: From the home screen, click on Settings>>General Management>> click on reset and then reset setting.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Thank you for writing to us.
Samsung Customer Support.
saiemk007
Galaxy M
I have done everything but stills same problem please solve my problem immediately
