My Samsung M21 is Auto Restart Problem Problem Help
(Topic created on: 08-15-2024 07:19 PM)
SILAN
Galaxy M
Samsung M21 is Automatic Restart Problem plzz Solve My Problem
4 Comments
SILAN
Galaxy M
After Software update I face this issue
goodthings
Galaxy M
Kindly reset factory data with backup then try to it's again also turn off Auto restart in device care too. If not resolves then go to service center it's may be a Motherboard issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
Your's most welcome to here.
cs_member10
Galaxy M
Dear Samsung Member,
Kindly use a genuine Samsung charger.
We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto restart function.
1- Tap on Settings> General management>Reset > Disable Auto restart (if enabled)> Auto restart disabled.
2- Tap on Settings> Battery and device care> Three dots> Automation> Auto restart at set times if enabled.
If you are facing this issue after installing any new application then uninstall that application.
Tap on Settings> Apps > desired app> Uninstall> Ok.
Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
Reset settings: Tap on Settings>General Management> Reset and then tap on Reset settings.
