My Samsung Galaxy M31s in battery drain fastly problem.
(Topic created on: 06-23-2022 01:25 PM)
SOLANKI_HIT_OFFICIAL
Galaxy M
My m31s may have been updated to Android 12 on May 9. There is no specific battery drain problem. But allmost 2 month complete . There is a problem with the battery drain faced. Please my problem solve in next update.
6 Comments
LISANTHlee
Galaxy M
Bro I'm using m30s same battery draining issue. Exynos 9611 is not battery efficiency processor
VINTAGE020
Galaxy M
My mobile phone is restarting automatically
cs_member8
Galaxy M
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
Batman0
Galaxy M
I have same issue. Samsung Galaxy M31s drains battery fast and heat quickly after android 12 update.
It also had auto restart problem. But I repaired it. Now, battery draining issue comes forward.
VINTAGE020
Galaxy M
How did u repaired auto restart problem ???
