M21 heating and battery draining issues
(Topic created on: 04-24-2022 12:04 AM)
sbera
Galaxy M
My m21 battery gets drain issue and heating issues...I go to samsung service center..after checking my phone they told me I have to change motherboard....is it right to change motherboard for this problem??
15 Comments
bodheet
Galaxy M
For what
bodheet
Galaxy M
No I haven't spend money I am just giving my opinion to change motherboard
Anfalanu
Galaxy M
If they said to change that then please do it bro.
Ashwinash
Galaxy M
It's common wait for next updates bro . . We also had this issue for m32 now working fine for m32 .
Prateek500
Galaxy M
Connect your phone with pc or other mobile with the help of otg until your phone starts showing charging animation . Press volume down and power button simultaneously untill the samsung logo appears , release the keys. There with the help of volume keys navigate wipe data factory reset option and press the power key to select after that restart your device.
cs_member8
Galaxy M
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
