I have Samsung M14 5g device has major data network problems and hang problem
(Topic created on: 02-10-2025 01:09 PM)
akarshyadav45
Beginner Level 3
Galaxy M
This device has major data network problem and when i am open mobile data so device gives hang issue and not working on commands properly
3 Comments
goodthings
Galaxy M
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
Your's most welcome to here.
cs_member10
Galaxy M
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
1. Galaxy device internet issue: https://www.samsung.com/in/support/mobile-devices/how-to-troubleshoot-mobile-data-issues/
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
2. Galaxy device hanging issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
