How to make battery πŸ”‹ indicator for connected blue tooth device
(Topic created on: 06-12-2023 04:15 PM)
natyNut
Galaxy M
Battery indicator is not 🚫 shown
5 Comments
umesh30
Galaxy M
Search in Settings > "battery percentage " and turn it on.
natyNut
Galaxy M
For Blue tooth audio device I'm asking
umesh30
Galaxy M
Oh I m sorry... But there is no option in mobile. Btw what is the version of your Bluetooth speaker... ?
Not applicable
Galaxy M
Go to widgets then find the battery section there you will find option to set widget which will indicate other connected devices battery percentage
Galaxy M
Use widget for battery indicator available in widget section
