Resolved! Solved
How To View Battery life of Bluetooth device?
(Topic created on: 08-14-2020 08:06 AM)
Vishanavi
Galaxy M
π™Έπšœ πšƒπš‘πšŽπš›πšŽ π™Έπšœ π™°πš—πš’ πš†πšŠπš’ πšƒπš˜ πš‚πšŽπšŽ πšƒπš‘πšŽ π™»πš’πšŸπšŽ π™±πšŠπšπšπšŽπš›πš’ π™ΏπšŽπš›πšŒπšŽπš—πšπšŠπšπšŽ π™Ύπš πšˆπš˜πšžπš› π™±πš•πšžπšŽπšπš˜πš˜πšπš‘ π™·πšŽπšŠπšπšœπšŽπš π™Ύπš— πšƒπš‘πšŽ πš‚πšπšŠπšπšžπšœ π™±πšŠπš› π™Ύπš› π™°πšœ 𝙰 π™·πš˜πš–πšŽ πš‚πšŒπš›πšŽπšŽπš— πš†πš’πšπšπšŽπš?
πš’ πš†πš˜πšžπš•πš π™°πš™πš™πš›πšŽπšŒπš’πšŠπšπšŽ πšˆπš˜πšžπš› π™·πšŽπš•πš™ π™Έπš— πšƒπš‘πš’πšœ π™ΌπšŠπšπšπšŽπš›?
Resolved!
Ehsank
Galaxy M
no in status bar but you can see in media section just near brightness level
Galaxy M
which Bluetooth device you are using...if it's Samsung level U, then you can download the level u app from the playstore...
Galaxy M
also if it's not a Samsung device then you can simply goto the Bluetooth icon and below that you can see the percentage of the connected device..
Not applicable
Galaxy M
ONLY if connected for Audio AND Calls..... otherwise it does NOT show anywhere.
manojvijay
Galaxy M
need to install 3rd party apps from play store to see battery πŸ”‹ %
Not applicable
Galaxy M
Not on Android 12.......
tuklu2021
Galaxy M
Samsung one ui is most worse πŸ˜‘ ui. Lots of features is not available also network aggressive issues. Not supported. Very old. Samsung need to update . @samsung do ur self
Bridgettelv
Galaxy M
This didn't work for me on my s22 ultra. I can't find a fix for this.  Tried a couple of apps that didn't work. Anything else we can do?
Not applicable
Galaxy M
You have to have Audio & Calls both active in the BT settings for each device, then you can select "Media Output" by swiping down from the home screen OR see connected BT devices in the settings menu, both will show battery % after Calls & Audio are both set to on. Works on my Android 12 S20 5G.Battery percent.jpg
