Resolved! Solved
Galaxy M35 5G fast battery draining problem
(Topic created on: 03-11-2025 02:55 PM)
Subhajit78
Galaxy M
Hey i am using galaxy m35 5g and I am facing a major issue about my phone's battery draining , i charge my phone to 80 percent and when I using my phone my battery get drain fast fast, although my all background app closed and put into deep sleep , please any suggestions or fix this issue.
goodthings
Galaxy M
4 Comments
goodthings
Galaxy M
goodthings
Galaxy M
Your's most welcome to here.
cs_member10
Galaxy M
Dear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
NaimIslam31
Galaxy M
Yes, I am also facing this problem.
