Galaxy M32 4G [Notification Sound Problem]
(Topic created on: 01-04-2023 09:12 PM)
Rajghosh06
Galaxy M
The problem is that I am not getting only Notification Sounds, when I go to Setting and check out in the varieties of playback in the norification section(in sounds and Vibrations), it doesn't sound even there.. I restarted my phone already twice...
By the way I am getting Calls and other Sounds through my Phone... this means speakers are working fine.
Then is this issue a BUG?
2 Comments
Ashwinash
Galaxy M
One ui 5 ?
cs_member8
Galaxy M
Dear Samsung member,
1. Tap the app's icon and look for Settings.
2. Tap the Settings icon.
3. Scroll down to find Accessibility (it’s under the Personal section) and tap on it.
4. Tap Notification reminder to open its settings page.
5. Tap the toggle switch from On to Off to disable it.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask question).
Warm regard,
