Major Notification Problem or Notification Bug Problem onSamsung Galaxy M21 2021
(Topic created on: 05-08-2025 04:56 AM)
Nikhil1265
Galaxy M
How to fix the *silent notification issue* in Samsung Galaxy M21 edition 2021
And *notification tone is not hear* and *notification popup* is not come in all applications so please I humble request to you please resolve this issue as soon as possible or otherwise provide the latest software update for Samsung Galaxy M21 edition 2021 ????😡😡🚨🚨📢📢🙏🙏
I am tired for this Problem
I hope you do this early as soon as possible.
* Silent Notification issue
* Notification tone is not hear
* Notification popup is not come
#Problemarenotfixed
#Notificationisnotworking
#SoftwareUpdate
#NotificationBug
#Problemiscritical
#M21Edition2021isnotworklyproperly
cs_member8
Galaxy M
Dear Samsung Member,
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Lock screen notification settings: Settings> Lock screen> Notifications and turn On> From here, you can customize the available settings:
1: Notification style: Choose between, Icons only.
Details: If you'd like more information about a notification at a fast glance, choose Details This option also lets you adjust notifications' transparency and auto-reverse their text colour.
2: Transparency: Adjust the slider to see more of your Lock screen wallpaper behind the notification.
3: Auto-reverse text colour: Automatically adjust the colour of the notification text to make sure it's readable against your background.
4: Hide content: Hide notification content in the Notification panel.
5: Notifications to show: Enable either Alert and silent notifications, or Alert notifications only.
6: Show on Always On Display: Show or hide notifications when your Always On Display is active. This option may not be available on all devices or when you are using Power saving mode.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
