Buzz/Static sound while listening to audio through earphone in Galaxy M31s
(Topic created on: 01-18-2021 06:49 PM)
Potat0Master
Galaxy M
There is a static/buzz sound while listening to audio through an earphone using the headphone jack on my Galaxy M31s
I have already tried in safe mode, but the issue is still there
My friend also has the same buzz problem in his M31s
And many other people online has reported the same issue
Replacing the device doesn't seem to work, the problem still remains
Resetting the phone to factory state also doesn't work
It might be software issue? Anyone has any solution like maybe tweaking some settings to lower the static?
16 Comments
A-
Galaxy M
Bro you are not the only one who is facing this issue...many m31s users are reporting this issue...
I think its software problem
Potat0Master
Galaxy M
Yes, I hope samsung fixes this soon :(
or if anyone has any temporary solution to this
A-
Galaxy M
I am too confused whether its software issue or a manufacturer defect ...
I think it is a manufacture defect...becoz wireless headsets are working well
Potat0Master
Galaxy M
I thought it was a software issue since a whole lot of users are facing the same issue. But now I'm confused too.
Maybe a whole batch of M31s has headphone jack defect
A-
Galaxy M
Right..
I asked my neighbour..he said that if we use mi earphones then it makes noise.. but while using boat earphones it doesn't make any noise...
Potat0Master
Galaxy M
But I'm using JBL earphone. Will probably have to buy a wireless one I guess
A-
Galaxy M
Yess...but I would suggest you to wait for some time ..let samsung take action
Potat0Master
Galaxy M
Ah okay, I'll wait and see then
Anyways, thank you :)
kuckaduck
Galaxy M
Same issue. Tried restarting the phone after being advised to do so in the Interactive Check in the Samsung Members app, all that happened was I'm now getting no sound at all through the headphones - after an initial buzzing sound anyway 😕
Is everyone who's bought this phone just going to have to get their hands on bluetooth headphones?
