Battery problems on wifi or cellular network
(Topic created on: 08-09-2025 10:04 AM)
LuckyMehra9999
Galaxy M
Battery draining most faster on wifi or mobile data after February 2025 security patch.
Currently July Security patch
3 Comments
BiRdMaN
Galaxy M
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
goodthings
Galaxy M
goodthings
Galaxy M
You're welcome to here.
