Battery drain
(Topic created on: 09-13-2024 08:23 AM)
SaiKrishnaSudhakaran
Galaxy M
Does anyone facing battery drain in samsung galaxy m35??
If yes ,pls tell me a solution ...
6 Comments
goodthings
Galaxy M
goodthings
Galaxy M
Your's most welcome to here.
Galaxy M
cs_member10
Galaxy M
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
Ryan46
Galaxy M
I am not facing any battery issues with this phone currently.
The phone awesome.
If you want a good battery health then turn off fast charging and leave your phone to charge at night and use it all day without any problem.
