05-22-2025 01:22 PM in
Galaxy M- Tags:
- samungindia
05-22-2025 01:23 PM in
Galaxy MDuring optimisation it may consume some battery.
Wait for atleast 7days.
Galaxy M• Check battery usage in settings
• Put unused apps to sleep
• Disable Always-On Display
• Set refresh rate to Standard
• Clear cache of high-drain apps
• Update all apps
• Restart device
• Wait for optimization patch from Samsung
05-22-2025 01:32 PM in
Galaxy M- Mark as New
Galaxy MAdd apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
05-22-2025 01:46 PM in
05-22-2025 01:49 PM in
05-22-2025 08:25 PM in
Galaxy M
05-23-2025 09:46 AM in
Galaxy MDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
