Battery drain issue galaxy m35
(Topic created on: 3 weeks ago)
babaibasu
Galaxy M
Please fix this problem... battery drain very first....
7 Comments
goodthings
Galaxy M
goodthings
Galaxy M
Your's most welcome to here.
dineshh
Galaxy M
Go to Device Care in settings. 1st battery tab, check apps consuming battery. Put most apps other than the ones which your need working in the background l, to sleep in same setting.
Royal_RJ
Galaxy M
On every device, the same thing is happening. Maybe the S25 series of devices were working fine without any issue, but others have the same issues.
Some series of devices are getting a lot, and some have minor.
cs_member10
Galaxy M
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
sreenandhkm
Galaxy M
Same issue face to m34😂
Galaxy M
Update u r phone and stop using 3rd party apps and check in battery options which app kill battery then uninstall it
Still you facing issues then factory reset it before resetvtake back up in Google drive ,one drive or samsung cloud etc which you prefer
I take backup in Samsung cloud
Click the three dots on my reply and select 'Accept Solution.' Thanks!
Follow me more information.
