Resolved! Solved
Battery Problem in M14 5g after One ui 7 update
(Topic created on: 07-19-2025 06:43 PM)
AsheerMalik
Galaxy M
Battery is draining to fastly. Anyone have solution?
Resolved!
10 Comments
cs_member10
Galaxy M
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
