Audio problems
(Topic created on: 10-05-2020 11:30 PM)
Ashzbro
Galaxy M
Scratchy sound while using Earphones is common in samsung devices?
Does anyone have these problems
8 Comments
adarsh98
Galaxy M
i have noticed recently in my earphone dont know why it keep happening need solution
Ashzbro
Galaxy M
which is your phone bro?
adarsh98
Galaxy M
m31
adarsh98
Galaxy M
i think after the latest September update i srtted to noticing it...first of alll i thoughts its problem with earphone but later I soon find it is from my phone itself
Ashzbro
Galaxy M
did you tried wireless earphones. I have scratchy sound in wireless earphones too
adarsh98
Galaxy M
i only tried wireless one my earphone is infinity n120
Ashzbro
Galaxy M
Okey bro
cs-member13
Expert Level 4
Galaxy M
Dear Samsung Member,
To resolve the sound problem kindly follow below given steps:-
1. Disconnect all accessories and remove any third-party case form your phone and check device volume settings if its full or not.
2. Reset the device:- Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
If the issue still persist kindly visit your nearby service center for the physical inspection of your device. You can search for the nearby service center from given link:-
https://www.samsung.com/in/support/service-center/
