j7 pro battery calibration issue
(Topic created on: 12-14-2018 09:37 AM)
ShubhamShukla
Galaxy J
My j7 pro seemed to be working great till recently i was busy to charge it in the morning it was at 24% and dropped very quickly to 1% in half an hour and operated another half an hour at 1% battery then died. It has some battery issues as sometimes it will run 15-20 mins on 75% and then roll to 72% quickly. Please fix this problem.
6 Comments
Tech4youbySid
Galaxy J
Please do a factory reset if optimisation is not working.
Gurmeet1
Expert Level 4
Galaxy J
callibrate battery search on you tube.
Vinja
Galaxy J
You might have to recalibrate your battery. Check out YouTube!
ShubhamShukla
Galaxy J
whats your screen on time on full battery
Shiv9564
Galaxy J
Run your mobile in safe mode to find out the faulty third party app creating the problem n delete them if problem continues go to service and change the battery
admin_
Galaxy J
Thank you for Joining Samsung community. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
