raymachhar
09-16-2017 09:05 PM in
Galaxy J
j7 prime battery charging problems after software updates
not up 90%
not up 90%
13 Comments
- « Previous
- 1
- 2
- Next »
Jackie007
09-17-2017 12:21 PM in
Galaxy J
same problem. my j7 prime shows 92% while charging and suddenly after 10 seconds it shows 97%. please respond and give a solution.
admin_
09-17-2017 02:03 PM in
Galaxy J
Thanks for query. We would like to inform you that this handset is enriched with most powerful features.Kindly follow below mentioned steps to overcome the issue:
1) We recommend you to charge your handset with original wall charger that came with your handset sales pack.
2) Kindly clean the charging point of your charger and battery with a dry and soft cotton cloth to remove unwanted accumulation of dust/waste material.
maheshsms
09-17-2017 03:31 PM in
Galaxy J
I just complete 3 month I got my j7 prime but also gives a problem please fix this charge problem
maheshsms
09-17-2017 03:32 PM in
Galaxy J
hamne sab try Kiya par koi faida nahi hua
- « Previous
- 1
- 2
- Next »
