Samsung j8 battery drain issue
(Topic created on: 11-02-2020 10:48 PM)
SriHarsha972
Galaxy J
after android 10 update the battery should suddenly dropps when it was below 20%
4 Comments
Not applicable
Galaxy J
I think you simply installed that big firmware via mobile data or wifi where the actual and recommended process is to flash that firmware via Odin or through authorized samsung service center or install via smart switch and pc otherwise software loop hole can hamper battery temporarily because samsung provides non A/B partition type ota software not like other company hence install any big os simply is not process because maximum time there will be chances to install software incorrectly or fully
Ehsank
Galaxy J
one of the main reasons of battery drain is even you close apps but they uses ur battery and running in background unnecessary, see image and read the statement.
2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Screenshot_20200731-222607_Settings_58499.jpgScreenshot_20200909-020608_Settings_60630.jpg
Ehsank
Galaxy J
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
cs-member13
Expert Level 4
Galaxy J
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
