Power Key Problem J7 Prime.
(Topic created on: 10-01-2017 11:25 PM)
snipranshul
Galaxy J
I am using J7 Prime. I updated my set second update of Nougat Update. After this Power Key is not working properly. Sometimes it does not working well. Please Samsung Check it and Fix it.
4 Comments
Not applicable
Galaxy J
check the hardwares using samsung members in diagnostics section
venktesh
Galaxy J
facing same prblm. turn lockscreen to none nd visit service centre
admin_
Galaxy J
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
bhavintandel
Beginner Level 4
Galaxy J
nice fon
