J7 max auto power off and battery showing 0%
(Topic created on: 12-31-2018 10:17 PM)
LittleTesla
Beginner Level 5
Galaxy J
My phone had 24% battery then suddenly it turned off and when i turned it on battery was showing 0%.
Anyone else experienced this problem?
Can anyone suggest me what to do?
Also it is charging very slow, sometimes i leave it charging overnight and when i check it in the morning it is 80-85% charged.
12 Comments
sahil5565
Galaxy J
same here bro in my j7 nxt
singhprakash
Beginner Level 3
Galaxy J
same here bro with my j7 max😤😤😤😤😤😤
uttamprasad
Galaxy J
same j7 16
Avadheshraj
Galaxy J
Right bhai mere phone ko bhi hota j7 max user hu
Avadheshraj
Galaxy J
some problam
Shiv9564
Galaxy J
Do you use original charger and cable?
LittleTesla
Beginner Level 5
Galaxy J
yes
Shiv9564
Galaxy J
Then go to service centre they will solve the problem
Galaxy J
better way to change battery or check board
