Does J7 pro battery supports fast charging.
(Topic created on: 10-30-2017 10:42 AM)
maharshi7
Galaxy J
can I use samsung fast charging adapter which is bundled with s8 in my j7 pro
Or it doesnot support fast charging.
9 Comments
maharshi7
Galaxy J
but the charger which is included is not fast charger i.e 5V~1.55Amp 😞
J717
Galaxy J
its same its amp is fast
and in fast charger its Voltage was fasr (9V)
its speed was same
admin_
Galaxy J
Thanks for being with Samsung and for sharing your concern. We would like to inform you that you need to use AFC (fast adaptive charger) and enable this under option Main menu >>setting >> device maintenance>> Battery >>enable fast charging. Adaptive Fast Charging is the smartest option to charging your Samsung mobile devices. Not only is it speedy, but it knows when to stop charging to prolong the life of your battery.
帕里克
Galaxy J
where is the fast charging enable option in j7 pro? i couldn't find it.
gaurav9995
Galaxy J
where is the enable fast charging option????
Venumkiller
Galaxy J
There is no such option and multiple user have replied to you about
Just dont post rubbish and **bleep** info
帕里克
Galaxy J
maharshi7
Galaxy J
yes i also didn't find😐
RV27
Galaxy J
there is no option...even when i plug it with fast charger(came with S7) it charges slower...
