Battery Problem
(Topic created on: 10-27-2017 07:09 AM)
KaifKhan
Galaxy J
Hi iam using Galaxy J7nxt only 2 months old. Now my battery is running or draining out fast than it was before. Can anyone please tell me the problem and suggest me the solution.
10 Comments
Galaxy J
Becoz of update
KaifKhan
Galaxy J
Are you Sure? Isn't this the reason for the problem because i have kept my phone switch off for 2 days??
MadhuG
Galaxy J
Go to Settings > Device Maintenance > Battery > scroll down to the bottom
You'll find two options unmonitored apps and always sleeping apps. Configure them as per your need to avoid battery drain.
KaifKhan
Galaxy J
Will this solve the problem?
sukha
Galaxy J
sir i have battery backup problem and over heat problem please solve me problem
sukha
Galaxy J
sir battery backup low night morning time. within 5 .6 hours 25% + Battery decrease night time 25% battery decrease sir please problem solve
sukha
Galaxy J
sir my phone is replese the mobile
admin_
Galaxy J
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let the community know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. "
KaifKhan
Galaxy J
Its mostly because of new update tht drains the battery i would recommend the company to provide an update for J7 nxt which will solve all battery related and draining issues
