Battery Problem
(Topic created on: 02-14-2018 12:22 PM)
dreamboynitin
Galaxy J
My device's battery charges very slow while charging above 88%. And it takes so much time in charging above 88%. Plz solve this problem.
8 Comments
roshini96
Galaxy J
open this👉 http://bit.do/samsung-app-link-download
Buntu
Galaxy J
same problem bro in j7 max
j7maX2017
Galaxy J
yes bro in j7 max its draining too fast
dreamboynitin
Galaxy J
What did U do for that???.....i mean how did you fix this battery problem????
Buntu
Galaxy J
Bro you having slow charging problem from 92%
Elatchian
Galaxy J
yea bro. i am facing exactly same isssue
admin_
Galaxy J
Thanks for being with Samsung and for sharing your concern. We would like to inform you that this handset is enriched with the best available features. Kindly follow the below mentioned steps to overcome the issue:
1) We recommend you to charge your handset with original wall charger that came with your handset sales pack.
2) Check whether UPS (Ultra Power Saving) mode or PS (Power saving) mode is activated (if yes Deactivate it during charging).
3) Kindly clean the charging point of your charger and battery with a dry and soft cotton cloth to remove unwanted accumulated dust/waste material.
4) Kindly follow the standard charging procedure (Charge your device for 150 minutes on switch off mode).
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
dreamboynitin
Galaxy J
I use original Samsung charger while charging....and i followed your standard charging procedure..but i didn't get any help by your suggestions.
Plz tell me any other procedure to fix this problem.
And still Battery drains too fast after charging the device...plz fix this problem
