Battery Problem
(Topic created on: 10-04-2017 04:31 PM)
dreamboynitin
Galaxy J
After updating my j7 max device, it takes so much time in charging and Battery is draining tooooo fasttt.......
I am facing battery problem......
PLZZZ HELPPP
7 Comments
Not applicable
Galaxy J
after which update??
dreamboynitin
Galaxy J
Menu> Settings> About Device> Software Update> Auto Update> Enable it
Not applicable
Galaxy J
do one thing. restore your mobile to factory settings. and i think your problem might resolve. i did the same thing and i really have a very good battery backup
dreamboynitin
Galaxy J
i have done ittt.......
i have formated my device twice.....
btt my problem has not solved
admin_
Galaxy J
"The issue which has occurred in your device requires binary updates and the same is already escalated to R&D team for rectification. Soon you will get binary update for the same via FOTA. i.e.
Menu> Settings> About Device> Software Update> Auto Update> Enable it."
dreamboynitin
Galaxy J
when will i get binary update....????
plzzz tell me
dreamboynitin
Galaxy J
i mean its a sofware update
