Title: Low Ringtone Quality After Setting Custom Ringtone on Galaxy F12
(Topic created on: 01-23-2025 02:15 AM)
SM_Dipankar
Galaxy F
Description:
Hello,
I am facing an issue with my Samsung Galaxy F12. Whenever I set a custom ringtone, the quality of the sound is much lower compared to the original file. It sounds distorted and muffled.
Here are a few things I have tried but the issue persists:
• Used high-quality MP3 and WAV files.
• Reapplied the ringtone multiple times.
• Cleared the cache of the Sounds and Notifications app.
• Tested different ringtones, including default ones.
Despite these efforts, the problem remains. My phone is up to date with the latest software version.
Is this a known issue? If so, are there any fixes or workarounds?
Looking forward to advice from the community or Samsung support.
Thank you!
8 Comments
TechieUS
Galaxy F
Check the Audio Format: Ensure your ringtone is in MP3 format and try different bit rates.
TechieUS
Galaxy F
Sometimes, even high-quality WAV files can cause issues because the phone's codecs might handle them differently.
TechieUS
Galaxy F
Try a ringtone, not try to make a song of 3:00 into 0:30
TechieUS
Galaxy F
Reset the Ringtone Settings: Go to Settings > Sounds and Vibration > Ringtone and set it back to a default ringtone for a while, then reapply your custom ringtone.
TechieUS
Galaxy F
Use Default Apps: Instead of using third-party apps, ensure you're using built-in apps for setting your ringtones.
SM_Dipankar
Galaxy F
Can you suggest me some third-party applications, if you know?
TechieUS
Galaxy F
Check Sound Enhancements: Disable any sound enhancements like Dolby Atmos or Equalizer settings. These can sometimes distort your ringtones.
cs_member10
Galaxy F
Dear Samsung Member,
We also request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
