Sound decrease problem in F55
(Topic created on: 03-07-2026 10:52 AM)
CreatorRaahi
Galaxy F
Recently when I woke up in the morning, whenever my phone rang the volume was low. I checked, the volume was not low but it was high.
Now I don't get any sound on calls, media, notifications or system. The volume of all these has automatically decreased even though I had kept them on high in the settings.
Please do you have any idea or solution for this?
This is Samsung, it's a multitude of problems.
cs_member10
Galaxy F
Dear Samsung Member,
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
