Selfie stick bluetooth remote control not connect with f23 5g
(Topic created on: 11-29-2023 01:12 AM)
Abul_Sheikh
Galaxy F
Today I purchase a Selfie stick and trying to pairing selfie stick bt remote control with my f23 5g device but it's not connect but i try to connect other phone like realme, oppo, vivo it's working fine. I check every single setings and reset wifi and bluetooth setings, camera setings but problem not solved.
so pls someone can help me to resolve this problem.
7 Comments
Galaxy F
Performance system settings reset & try again
Abul_Sheikh
Galaxy F
I already reset system setting
Galaxy F
Wait for stable update release
KUNAL_1
Galaxy F
Is this UI 6.0 on F23 ?
KUNAL_1
Galaxy F
Wait for stable release of 6.0 might be software compatibility issue for now.
Abul_Sheikh
Galaxy F
Yes
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, we request you kindly contact the respective selfie stick company helpline to confirm if is there any supporting application available to use the selfie stick or not.
If any application is available then kindly use that application.
If the issue still persists kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
