Samsung f23 5g battery drain fast
(Topic created on: 06-14-2024 03:52 AM)
ARJUNB
Expert Level 3
Galaxy F
I use my phone 80% till 20% now see if this is acceptable or what can be done here.
I don't play games. I use phone for calls, what's app cctv camera some reels for a while. Yeah that's it. Plz advice. How can we it better?
10 Comments
Gaming6698
Galaxy F
That's what 5G capable of. 5G drain battery alot faster.
Some tip- Put all apps deep sleep (expect those app from which you need messege like Whatapp) , zip apps that you won't use too much, disable nearby scanning, usage and diagnostic setting, android personalisation service from setting, disable print service from setting,
I have same phone f23 5g and I charge my phone everyday single time in morning and always use battery protect feature (Maximum 80%) . I able some games, instagram, youtube. But I use 4G since 5g is not available in my area and 5g drain lot battery. So use 5G when I am in another town and need to download download some file's.
BTW, I do notice that battery drain faster in one ui 6.1 and developers are surely aware of this so we probably get battery fix update soon..
I know many thing about pc and phones so I optimized my F23 for battery and performance alot. Some tip I give you above is from my optimization which can be done by anyone.
See my charge is still 80% with almost 1hr screentime.
Galaxy F
Incase you don't keep your phone's data always on you can set the following routines like I do.1718339074812.jpg1718339082459.jpg1718339082509.jpg
cs_member10
Galaxy F
Dear Samsung Member,
We want to inform you about the Samsung Members app (Battery Status (Battery life + Battery Capacity).
You can check the "Battery Status (Battery life + Battery Capacity)" test using the Samsung Members app.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
We would like to inform you about the standard charging procedure (charge in one go instead of charging many times as it affects the life span of the battery and battery performance).
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level.
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps.
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Ajay_das
Galaxy F
Call to customer care 1800407267864 Complaint dere battery draining issue, say next update plz recover
Prakash83
Galaxy F
Vonr not available
ARJUNB
Expert Level 3
Galaxy F
Athul159
Galaxy F
Charge the phone when it reach below 30%
U will get better battery
Sameer
Galaxy F
I have tried to address this issue in my video ...
https://youtu.be/DXM7pdW5a-w?si=_uL2LE-EYk5c8lY8
Make the following changes and wait for 2 weeks, post making all changes ...so that it studies the usage patterns and later battery life is enhanced ...
This you tube channel is only about Samsung and will cover some exclusive content (not covered by Any channel) ...
If you like the video, please subscribe and hit the bell icon for all future updates
ARJUNB
Expert Level 3
Galaxy F
Good video. But the interesting part of the video is that everything you have shown I have already done it on my phone.
