Samsung Galaxy F34 battery draining issue
(Topic created on: 10-17-2023 08:15 AM)
Koustav05
Beginner Level 5
Galaxy F
My New purchased F34 has a serious battery draining problem... it's 6000 mah battery iw looking like 4500 mah backup...!! It doesn't last for a day... phone is in latest software.... battery is also draining in standby mode!!!
16 Comments
Soul_Catcher
Galaxy F
Should have purchased M series
Deb7890
Galaxy F
M and f series are same
SRK62
Galaxy F
I'm also facing same problem.
My device F34
TiberSeptim
Galaxy F
Have you tried using the recommend charger by samsung...
I presume your not using a 25w charger...
I don't know why but mostly in samsung phones if you use any other wattage the battery seems to misbehave...
Also noted this when charging IPhone 15 with a higher rated charger ( 120w )
Try using a 25W charger and update if solved.
Galaxy F
Using 22.5W charger....not having any issue
SRK62
Galaxy F
I'm using 25w charger since purchased the mobile.
Charging is super fast and discharging is fast.
I'm also using deep sleep apps and adaptive power saving and many more, but same problem discharging fast.
TiberSeptim
Galaxy F
Yes the phone is discharging faster than usual for a 6000 mah..
I am seeing a small difference when i turn off 120hz refresh rate and always on display...
Always on display is always pulling 120hz even when not using...
Definitely some optimization issue. Hope is resolved with an update.
Ayan123456789
Galaxy F
Same problem
niloy234
Beginner Level 4
Galaxy F
Which charger you use.
