Regarding Notification sound issue
(Topic created on: 3 weeks ago)
Milosen
Galaxy F
Facing a problem of receiveing Notification sound in my device without getting a notification in my device(F06)
3 Comments
goodthings
Galaxy F
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. Also go to service center for check and resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy F
You're welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
