Problem when using double tap power button
(Topic created on: 09-29-2023 12:38 AM)
KVANA
Galaxy F
I having some problem whan using double tap power button on galaxy F23, I use torch on and off, torch on smoothly but not off, I need to use quick panel, is anyone having this problem?
8 Comments
iamMUKESH
Galaxy F
May be in next update, it will get solved
KVANA
Galaxy F
I'm using this feature since day 1 using f23, it working properly in previous but nowadays it's not.
umesh30
Galaxy F
I have tested it right now. I don't have to face this problem. When I double-click a second time, the touch is turned off easily...
Please turn off and turn on the side key double press option again...
KVANA
Galaxy F
Okay, I'll try. Thank you 😊
Record4
Galaxy F
Working fine in my device A53 5G.
How many days have you had this problem? I think it may be a software bug.
Restart your device. If it wasn't solved, send feedback to Samsung.
From Mahammad Rafi.
KVANA
Galaxy F
About last 2 days I having this issue. Okay I'll send feedback to samsung. ☺️
emarld_22
Galaxy F
No problem it is working fine
KVANA
Galaxy F
Ohh okay
