Heating problems and network issues
(Topic created on: 10-08-2023 08:12 AM)
techyNEERAJ0708
Galaxy F
After update my Galaxy F62 it behavior very bad experience. Device getting very heat in normal use and network also very poor 😢 please fix this problem
8 Comments
hellogoogleee
Galaxy F
Samsung
hellogoogleee
Galaxy F
Reset karlo ek baar device ko
Galaxy F
Bhai data chala jayega
hellogoogleee
Galaxy F
Backup karlo
Galaxy F
Bhai 110 gb ka h possible nhi h
Galaxy F
Network issues have been a problem since the F62 was manufactured, the antennas used for this device are of cheap quality .
Galaxy F
Right bro. I don't know why Samsung do this 😕 25k phone
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, kindly visit the mentioned links to resolve your issues:
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
