Resolved! Solved
Galaxy F23 Battery Drain Issue
(Topic created on: 09-13-2024 12:16 AM)
Not applicable
Galaxy F
I have been experiencing heavy battery drain in my Galaxy F23 since last 2 days. I don't know why is it happening all of a sudden.
Even though I have restricted my battery charging to 80% only so I expected my battery life to be good and I had enabled this featured since the day of buying this phone I.e around 1.5 years back.
There's no issue in the Charger or the Adapter.
Can Somebody tell if you've been facing the same.
goodthings
Galaxy F
8 Comments
ARJUNB
Expert Level 3
Galaxy F
This is my f23 5g battery health I also use 80% till 20% but get good battery life no issues 1726176181614_1726176181603_0.jpg
goodthings
Galaxy F
He is right, some battery drain issue after August Security Patch Level Update. Please check. Thanks.
ARJUNB
Expert Level 3
Galaxy F
Mine is also latest update but I am getting good battery backup. Look for saving battery one has to follow some steps the any phone will give good battery backup.
ARJUNB
Expert Level 3
Galaxy F
Same 1. 5 years old phone mine 2
goodthings
Galaxy F
Not applicable
Galaxy F
I have done it. Let's see what happens.
goodthings
Galaxy F
Your's most welcome.
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
