CONTACT STORAGE BATTERY DRAINING ISSUE
(Topic created on: 05-30-2024 03:41 PM)
JAGANMENON
Galaxy F
I taken f54 to mainatain my whole day business need thru battery..but am surprise d its battery drains fast due to contact storage isuee..dont know what it is
Please reply or give me a solution..am really trapped
6 Comments
JAGANMENON
Galaxy F
Can anyone give me a reply in my samsung f54 (contact storage battery draining issue)is a software issue / it will be solved in next update or not?1717117368761.jpg
Not applicable
Galaxy F
Battery drains fast in my phone also.
JAGANMENON
Galaxy F
I found a temperory solution for my contact storage battery drain problem..
1)use samsung ui as default launcher avoid other launchers
2)take apps,in that take samsung contacts,clear it full data and cache file and restrict all its permision..
2)use google contacts for our use and turn its syncing off with google..now my battery draining due to contact storage decreased from 20% to 4%
3)take device care and clean its residual memory once in a day..mainly contact storage one
cs_member10
Galaxy F
Dear Samsung Member,
As per your concern, we want to inform you that the usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. Kindly perform the following steps to resolve your issue by using the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Ajay_das
Galaxy F
Call to customer care 1800407267864 Complaint dere battery draining issue, say next update plz recover
Sameer
Galaxy F
Watch this video specifically created to enhance battery life of Samsung phones ...
https://youtu.be/DXM7pdW5a-w?si=4ViI0DhjN4qmVjWG
Wait for 2 or 3 weeks post the making these changes in the video ...for the phone to study the usage patterns and enhance battery life ..
Do Subscribe to this video and click the Bell 🔔 for all exclusive videos
