Battery draining to fast & not showing estimated Battery time
(Topic created on: 05-08-2023 12:32 PM)
vamshi6211
Galaxy F
I bought samsung galaxy f23 on 6th of may .. unable to get estimate time of battery plz help me and also battery draining to fast I'm not installed much more apps 😥 please reply me soon
#samsung
5 Comments
KSac_H
Galaxy F
It's learning your usage pattern don't worry. It will show soon.
Not applicable
Galaxy F
Bro same problem
Not applicable
Galaxy F
It will show after 5-6 days. Dont worry
emarld_22
Galaxy F
Wait for 2 to 3 days it will show
cs_member10
Galaxy F
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
