Battery, camera and heating issue in samsung f54
(Topic created on: 03-08-2024 02:30 PM)
Kpf54
Galaxy F
My f54 model of samsung is heating too much during daytime without using it.
Second after updating to android 14 in f54 now it's camera quality has become dull. There is no difference between shot capture from 12mp and 108 mp. Both are capturing same detail and also it's quality is also not much impressive. Same is in case of selfie camera. When we capture from 12 mp and 32 mp there is only a minor difference. We have invested 30k for this mobile but it is degrading day by day specially after android update. Samsung should bring immediately new update and optimise f54 camera and battery.
I bought this mobile for camera and battery but these are not upto the mark. Having 6000 mah battery still I did not get more than 8-9 hrs of battery backup with continuous use. I tested this more than 1 month and still same problem. I only watch youtube and 1 hr ludo only. Still bad battery backup specially after one ui update.😡
18 Comments
goodthings
Galaxy F
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution .Thanks.
goodthings
Galaxy F
Your's most welcome to here.
cs_member10
Galaxy F
Dear Samsung Member,
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device camera issue: Follow the easy troubleshooting steps which might help to solve the issue.
Check physical condition of your camera lens.
Broken camera lens>> Scratchy camera lens.
Note: Please check there is no laminated or tempered glass pasted on camera.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt and dust from the camera lens.
Reset camera settings:
From the home screen tap on Camera>>Tap on Settings>>Scroll up and tap on Reset settings>> Tap on Reset.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
In case the issue still occurs, please register your concern in the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Kanhaiah
Galaxy F
Even I have the same issues. Trying to replace with other phone soon.
shubh001
Galaxy F
rajshyamabhatt
Galaxy F
I have sumsung f54 I bought it recently about 15 days ago and facing network issue like 4g to 5g automatically. I am also facing fast battery drain issue it doesn't give battery backup more than 8 hour. After using it only on 60 hz. So I hope this bug will be fix by sumsung.
Kpf54
Galaxy F
Yes it's battery is lasting not more than 6 hours in 120 htz
aksoct1979
Galaxy F
Bad battery and heating too much without use
laslalsa
Galaxy F
Too much heating in new Samsung f54
