Heating issue while charging and ringtone volume getting low automatically.
(Topic created on: 03-23-2019 12:41 AM)
KingmakerFaiz
Galaxy C
Hello samsung ! From few days i am facing few problems in my device. My phone ringtone volume automatically set in lower level and i also facing Very HUGE HEATING issue while charging, playing games like asphalt 8 & pubg on so on....
Plz fix this problem
5 Comments
popat
Galaxy C
remove mobile cover while charging time heat dissipate problem was created in that situation
Abhaaggarwal
Galaxy C
heating is normal put a cloth under your phone (with removed cover ) while charging and use device maintenance regularly at least 5-6 times a day to solve your heating problem
pain7246
Galaxy C
if you want to play gaming while charging then it will b heated most. So better to charge it first and then play or use a napkins and mix it with cold water and put behind the back of the mobile to avoid heating.
Galaxy C
remove mobile cover while charging, and do factory reset.
sammisam
Galaxy C
oooohhhh
