please battery drawing problem of a51 after September security patch
(Topic created on: 10-16-2020 10:53 AM)
loveraj
Battery drawing problem in samsung a51 otherwise phone is perfect
4 Comments
PAULjose
yeah bro I also felt some battery drain issue ,but not much. When the phone kept idle the batter is drain out. Hope the next update will optimize the system to solve the issue.
Ehsank
one of the main reasons of battery drain is even you close apps but they uses ur battery and running in background unnecessary, see image and read the statement.
2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .Screenshot_20200909-020608_Settings_60630.jpgScreenshot_20200731-222607_Settings_58499.jpg
Ehsank
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
Samsung_Support3
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
